Side stand issue GL1100
1222 Views 17 Replies 6 Participants Last post by  plskthompson
I just installed a set of Markland floor boards on my 80 1100 with a heel toe shifter. Everything seems to be working fine except the fact that the side stand is hitting the shifter at times. It takes a little more effort than I would like to shift at times. Any one have a fix for this other than removing the boards and going back to the pegs and original shifter?
By the way I have already done a search through the forums and also checked the index to no avail, so its up to you guys.
1 - 18 of 18 Posts
I have had the Markland boards on mine since it was new and I don't see how the side stand can get anywhere near the shifter. I don't have a picture with the stand in the up position. But when up it is well under the H/T shifter.
My Markland setup is slightly different than most I've seen. It doesn't use the original shifter. It replaces it with a linkage rod instead.
Need a pic.
dingdong wrote:
Need a pic.
Here's the pic you wanted.
I see you have it on the center stand with the kickstand in the down position. Now post one a little bigger for detail with the kickstand in the up and riding position in order to ascertain the clearance problem with the shifter.
The red circle and arrow are pointing out what I believe is the problem. Hope this helps come up with a remedy.
See if this helps. It's the best I can do. It's the post that holds the spring onto the side stand.
Sorry, I can't make out that last pic well enough to suggest anything. Can you re do the pic a little larger so we can see more of the shifter lever?
Try the edited pic. See if that helps any at all.
So the shifter hitsthe spring peg on the side stand and this prevents you from pushing down on the heel end of the shifter .
1 I would see about putting a little dab of weld on the side stand so it doesnt raise up quite so far .
2 Adjust the linkage so the heel end is higher up ( though that might make the front to low.
3 Apply some heat to that bow in the shifter where its hitting and raise it up .
just some thoughts from a non user
You have the Markland Model I, they were sold between '75 and '77. I had the model I on my '75 GL1000. I don't remember having the problem you have but that was a long time ago. As Wing&Prayer said, you can adjust the linkage to allow the heel end to come up a little higher in the frame but be careful, if it gets too high you may not be able to down shift. I would look for something I could clamp to the rear bar on the floor board frame so the side stand spring knob could hit that and keep it a little lower. Be aware that this could decrease ground clearance in a turn.
Why don't you put a spacer behind the floorboardmount where it bolts to the bike frameand move it out to the leftsome?
Here are Pictures of my shifter, looks like the same one as yours hope it helps.
Mine does not hit at all.
Tib:cool:
next picture
last picture
Tib's pics is the type and size we need to see.
My pic's are I re-sized to 800x600
and it looks to me that his heel is set to low to clear the side stand.
I would try a spacer, but the thread shaft is just long enough now to get the nut started. I think I am going to try and adjust the linkage, though. It looks like Tib's is set just a little lower in the front than mine. I just hope I don't run into any down shifting issues.
1 - 18 of 18 Posts
