Master Sgt. USAF Retired.
Has anyone successfully installed the Signal Dynamics Wig Wag modulator? If so...did you tie into the circuit at the C10 connector? If not; where? I want to "wig-wag" all of the brake lights. BTW the circuit diagram in my service (shop) manual is poorly printed...I need a magnifying glass to read it.:cool:
1999 GL1500SE
Norm
Thanks Earl, I decided against tampering with the C10 connector and hard wired the system for the upper lights only. Should of went that way in the first place...it would of saved me several hours of messing around under the seat. On the other hand, I sprayed and cleaned all of the exposed connections and tied up some wires that were a little loose. I installed the controller, out of the way, in the foward right side of the trunk. The way I did it; you have to look hard to see the wiring harness. The unit works great. Now comes the "digital battery monitor."
Norm
Dont know if you guy have seen these on e-bay but I bought a set of led tail lights that plug right in to the standard bulb. They will start flashing when you apply your breaks,and you dont need to do any rewiring. I pulled the covers of the upper break lights in the trunk and swapped bulbs easy. Hal
