1 - 11 of 11 Posts
Here is a question? If the silicone rectifier in the clutch and neutral indicator circuit is missing or faulty will this prevent my 1200 Aspencade from starting:confused: .Many thanks Dagodave
rectifier
Many thanks Ciaran i have just started to restore my wing and the guy i got it from said it was missing, is it a common silicon rectifier if so i should be able to get one from RS spares or Radio Shack. On different tack i have spent many hours fishing the Barrow and the Slaney at Craignamaner and drinking in Fethard.Happy days, Best wishes Dagodave
In a short answer, Yes, from looking at the wiring diagram, this diode should be in place in order for the start circuit to be completed.
Discussion Starter · #8 ·
rectifier/diode
Confused is it a diode(current flows one way )or a rectifier converts ac to dc more to the point what is its function in the clutch and neutral indicator circuits dave c
Junior Grue
The diodes function is to isolate the neutral indicator light from the clutch switch.
If it's shorted "passing current in both directions" the neutral light will come on each time the clutch is pulled even in gear.
As Dave said, if it's missing the neutral switch is no longer connected to the start switch and the clutch "over ride" switch will need to be used for starting.
Yes it is a diode, Honda chose to call it a rectifier instead. A rectifier is a group of diodes arranged to divide the +&- sine waves of AC into a DC square wave.
1 - 11 of 11 Posts
