While I have the entire fuel injection system apart, well at least off the bike, I have most of it back together now, I was looking at where the throttle cables go. Does anyone know why this bike has two cables? It has a "pull" cable, and a "push" cable. The "push" cable really doesn't do anything. The pull cable opens the throttle, and the spring on the air chamber where the throttle linkage is mounted to closes it. If the pull cable were to break, the spring would close the throttle.
The reason I'm asking is because my '04 Honda Rebel and '02 Vulcan 750 both had dual cable throttles, and I couldn't figure out what they did either. One person on a Rebel forum was having problems with his throttle not closing because the push cable was sticking. I got to looking at mine, and simply could not find a reason for it, so I removed it. The throttle worked much smoother, and snapped back much easier without the drag of the push cable, so I removed it from the Vulcan 750 as well. Same resullts, throttle closed easier. this was a couple of years ago, and I have had no problems with using one cable. My '94 XT225 only came with one throttle cable, and it works fine.
Is there really a need for the push cable on the Goldwing? One thing I am absolutely certain of is it is not a safety device, it is actually safer without it. Binding in this cable could cause the the throttle to not close when released.
