I purchased the juan hernandez kit from ebay with the aluminum manifold and the solex 34 pict 3 carb. I got everything installed and running. I adjusted the carb by the instructions on the vw sites. she idles good and runs good with a couple exceptions. under normal take off (slow and easy), she runs good, on hard take off (like you stole it) she runs good. running down the road hi gear 55 mph, if I open the throttle wide open she will stumble bad, open it gradually she does good.
Second: I don't seem to have the top end that I did before. I can get about 95. I did not have a long stretch of road to keep going. the throttle response is good under load, runs like a scalded ape...
I have read that this carb is used on 1600 cc vw engines...
