I have owned a '94 and a '98 and I don't recall ever needing worry about that.
Ditto, if fluid did leak out of the slave cyl. it should run out the weep hole instead of into the engine. I doubt a little brake fluid would hurt the engine if it did.That seal doesn't keep brake fluid out of the engine, it keeps engine oil out of the slave cylinder. If you don't have engine oil in the slave, the seal is doing it's job.
Removing the seal without ruining it? Nope, you will damage it by taking it out. If you do need to change it, you can drive a drywall screw into it, and pull it out with a slide hammer.
Just one of those things someone who knows little but people believe because they can write a manifesto in a forum post said once upon a time and it grew from there.
That's nice to hear. I made the same deduction when I rebuilt my slave cylinder on my 1200i. I didn't replace the seal more out of fear, to be honest, but found only brake fluid weeping from the hole.
