I'm in the process of rebuilding the carbs on my 82A. In taking the vacuum chambers off each carb and the slides with needles, I have one needle that is firmly set in the slide, unlike the others that are wobbley (?). Does anyone have a suggestion as to what I might do to loosen up this particular needle? Thanks, Dan.
Wow, that's a new one. How about some PB Blaster?
EDIT: I see what you're talking about. Thought you meant the needle was stuck in the seat.
On a 1000 carb the needles are removable. They can be unscrewed using a straigt blade screwdriver from inside the slide. If you go this route make sure you pay strict attention to any washers under the screw as this is a critical tunning point. If it were me I would take that one apart and another one and try to determine if they are setup differently.
Banned
just as Whisker said, goes for the 1100's. there is a plug on the top of the slide, remove that and take a flat headed screw driver and remove the needle
I had one on my 1200 stuck. It was stuck with varnish. Some spray carb cleaner should do the trick. Dont overdo it as that stuff is harmfull to your seals.
It took a bit of PB Blaster and about 30 seconds soaking to break the slide needle loose. Thanks for the suggestions.
Dan
