When I am at idle I hear a slight ticking noise,if you rev it up above 1500ish it purrs like a kitten,it has done this for a while now.
I notice when taking off from a stop there is that light ticking noise till its over 1500 rpm or so.
I change the oil every 3k and use Honda oil from the dealer I bought it from.
It seems to come from the gear shift side.It's not very loud,isn't a knocking noise by any means.
It has 16k on the clock.Just changed plugs.
Also,it never has liked 1500 rpm,if you are in first gear and tooling along it will fuss and lope,anything above 1500 or below is just fine.
If you are parked and rev it to 1500 rpm it will start to lope up and down about 200 rpm.1700 Rpm or 1300 rpm and it's fine.
And one other thing,why do Wings "whine" at lower RPMS?
