Im getting frustrated and need some input. I put together an 80 gl1100 motor, that runs fine butsmokes excessivly. The smoke does not smell like Oil or coolant, Nor is it black. The bike does not always hesitate but occasionaly will bog down from low end. Carb has been syncronized and recently overhauled. Cyliners are fresh and have good compression. Black thin fluid comes from exhaust connection. I have been through just about everything on this bike and dont know how to isolate this problem. Valve clearance was set to .0005 on intake and .0004 on exhaust. Timing marks line up with tdc on both heads. It doesnt seem to be loosing or mixing any fluids. I thought initially that this was pre-assembly oil, but after running a few hours it hasnt cleared up. It also doent do this at first start up, it has to idle a while. My thoughts were leaning towards a rich condition, but idle mixture screws do not seem to effect this issue. Any help would be appreciated (aside from a seafoam recomendation
