Thanks. I drilled out the threaded bolt that comes out of the cylinder which the shock slides on too. Now I feel like my bit is hitting frame and going nowhere. Will I be able to drill through. I'm assuming that I dont cut off that cylinder which the shock slides on.
It should be hollow behind where the stud comes out from. Its a welded on stud that comes off the upper side of the frame. With the shock off, you should be able to fill behind the area. I used a stainless grade 8 bolt when replaced.
