1 - 13 of 13 Posts
So one cool night I turned on the heated grips and thought they seemed comfy at level 4. Saturday I was out and turned on the seat and grips heat to max, and I wasn't even sure they were on - but then again I was almost home. This morning I went out to the garage and idled the bike with the grips and seats at max and it took a while -15min beforethe chill started coming out of them. So, how warm should they get, and how long should it take? It was around 50F at the time.
Cheers,
Kerry
How long? Quite a while (longer if you are moving as the wind draws the heat away) How warm? ...Not very
I thought I read there is a amibeint temp minimum before they come on?
Rode a rented 2010 through rain, snow and hail in mountain passes. My Icon leather and mesh gloves were soaked but with the grip heaters set about 6-8 my hands were toasty. Max setting was nice for a few minutes after stopping but I had to turn them down shortly. I wonder if they've been improved from '06 to '10.
Steve
They must have improved between 06 and 10. The 06 model only goes to 4. What next...11 ? (cheap Spinal Tap reference)
I may have the numbers wrong...may have been through 4 with dots or something between. I know setting them on max was too hot but they sure were welcome with cold wet hands.
Well don't I feel dumb!!!!
:cheesygrin:
I installed a Utopia backrest andhand wingson my Wing today and when I pulled the seat off, the heater wire wasn't connected!!!! A couple of weeks ago I had the seat off when I did the air filter and I either didn't plug the seat heater back in, or didn't get it snapped tight. So, now the grips and seats heat up great! I think when I figured last weekend that the chill was coming out of the grips, it was only the warmth from my hand, or else I was just fooling myself.
We went for a ride for a couple of hours today at 9C (48F) and really appreciated having the seat and grip heat. And the backrest is excellent too!
Cheers,
Kerry
Good find. Glad it was that easy.
I read that Honda wired the grips and seat heaters through the bikes ECU. Unlike the old style heated grips that dumbly responded to the switch setting - they are regulated by both ambient temperature and the switch setting.
probably explaines why mine dont heat up in 60 degree weather or they just quit working all together.
1 - 13 of 13 Posts
