rOmiLaYu wrote:
I just put a new starter in my bike and on about the third crank, the SOLENOID quit responding. The solenoid still clicks, but can it die and still click?
The starter is fine....screwdriver tests shows that.
rOmiLaYu, SURE it canclick & not power the starter..
Well if the starter turns good with a screwdriver test that means the battery must be up & the B+ cable & ground connections good, so that leaves either a bad cable connection at the relay (solenoid), or a poor start switch problem,,or partial open in the starter button circuit or bad ground onthe relay's low (ground) side), or bad contacts in the relay (solenoid)..
First, check the relay's ground side while trying to crank, if any voltage there suspect a failing clutch or trans switch, or high resistance wire on that side,, then check for over 8-9 volts (start button held down) on the switch side of the relay, if OK there you probably have a bad relay.. You can take it apart & clean the contacts, orin some instances remove the center & flip the contact strip over. In most cases, if the relay clicks that meansthe circuits to it are good but if the pull in power is low it can click but not make the contacts fully close..
Twisty
