Hello everyone!
I have a 1978 gl1000 with a Solex 34 pict 3 carb set up, apparently the previous owner started the conversion and mounted everything in place (manifold & carb) but no electrical connection to the electro magnetic cut off valve nor the choke heating element, for some reason the cut off valve in my carb is missing and I just wanted to know if it is totally necessary for this set up and have to order it or just plug it off
thank you in advance.
Ps: picture of my carb were previous owner just cover the threaded hole with a tire air valve you're seeing the part that goes inside the tire and it took me a while to realize that until I pulled it out I thought I was going crazy😂
