1 - 9 of 9 Posts
Ok, so can someone fill in the following numbers for a 1984 GL1200?
Max HP @ RPM:
Max Torque (Ft/Lbs):
Top Speed (MPH):
0-60 MPH time:
1/4 mile time / Speed:
Powerband:
Tpo speed: 118.7
1/4 mile: 13.11 @ 96.2
Still haven't found 0-60, except anecdotal, 3-4 seconds.
No HP or torque curve either.
Found this at http://www.nakedgoldwings.com. '84 was the last year for the Standard version of the GL, and I'm thinking these numbers aren't for the dressed version.
GL1200 Engine type
Horizontally opposed 4-Cyl. 4 stroke
Liquid-Cooled belt driven SOHC w/rocker
arm valve actuation two valves per cylinder
Bore Dia: 75.5mm (2.973 in)
Stroke: 66.0mm (2.598 in)
Compression ratio: 9.0:1
Displacement: 1182cc (72.1 cu-in)
Adv [email protected]: [email protected]
Maintenance adjustments and capacities
Engine oil: 4.2 US qt (4.0 liters) After draining
Spark plug: X24EPR-U9 (ND), DPR8EA-9 (NGK)
For cold climate: X22EPR-U9 (ND), DPR7EA-9 (NGK)
For extended high speed: DPR9EA-9 (NGK) or X27EPR-U9 (ND)
Plug gap: 0.8-0.9mm (.031-.036 in)
Cooling system 3.4 US qt (3.2 liters)
Fork oil: 11.66 US oz (345cc)
Fuel Capacity: 5.8 US gal (22 liters)
Carburetion: (4) 32mm CV
Float Level: 9/32 inch (7.5mm)
Fuel pump: Flow rate Per minute: 500cc (16.9 fl oz)
Pilot screw setting: 3-1/2 turns out (under 6500 ft)
Tire size front: 130/90-16 67H
Tire size rear: 150/90-15 74H
Dry Weight: 600lbs (272 kg) with oil and
fuel tank: 652lbs (296 kg)
Veichle capasity load: 505lbs (229 kg)
Charging System: 360W @5000 rpm, Leakage 0.5 mA max.
Output volts: 14.6 volts 3000 rpm
Battery capacity/type: 12 volts, 20 amp-hours
Front Suspension: air-assisted telescopic with TRAC[tm]anti-dive
Rear Suspension: air-assisted dual shocks
Front suspension pressure: 0 - 0.4 kg/cm (0 - 6 psi)
Rear suspension pressure: 0 - 4.0 kg/cm (0 - 56 psi)
Seat Height: 30.7 inches (790 mm)
Overall heigh: 46.1 inches (1170 mm)
Overall length: 92.7 inches (2355 mm)
Overall width: 36.2 in (920 mm)
Wheel base: 63.4 in (1610 mm)
Ground clearance: 5.5 in (140 mm)
Valve clearance: Hydraulic auto adjusting
Final drive: 4.5 US oz (130cc) Hypoid Gear Oil SAE 80
Idle speed: 1000 rpm ± 100
Steering caster: 60° 00'
Trail: 118 mm (4.6 in)
Color: Black and Candy Wineberry Red
Front Wheel Bearings: 6302/6302 (Pair)
Rear wheel bearings: 6204RS (driveshaft side)
and 6304RS (disc side)
Brakes
Twin disc front w/dual piston calipers
Single disc rear w/ dual piston caliper
Integrated braking system was standard on all models.
T.R.A.C. damper force:
1. Light anti-dive
2. Medium
3. Hard
4. Maximum anti-dive
Gear ratios
Trans Primary: 1.708
Trans Secondary: 0.897
1st: 2.643
2nd: 1.667
3rd: 1.250
4th: 1.000
5th: 0.829
Final Drive: 2.833
Banned
There's immense drag, ive ridden without it. Mainly the windshield and Id hate to be without that - i got spoiled when switching to fairing bikes early on. I suppose a "buddy shield" would do the trick if one didnt mind the shorter windshield. Passenger would get drowned in the rain.
1 - 9 of 9 Posts
