1 - 2 of 2 Posts
1986 SEi gl1200
I have a spare SEi engine and I inject a bit of oil thru the plug holes each year and turn it over a bit to keep it from seizing. Is this the proper procedure or do you recommend any thing else? Also what is recommended to bleed the brakes or procedure I should follow? Does one need a bleeder device or kit, and if so, what works best? Haven't done this before so want some advice? thanks
1987 GL1200 Interstate
Certainly won't hurt to lube the cylinders.
Some have no trouble hand bleeding brakes. Some like speed-bleeders.
I prefer the MityVac.
1 - 2 of 2 Posts
