Only the SE got the proper Honda fader which is mounted on a nice housing near the ignition switch. If the one you have is a small aluminium knob fitted to the left side knock-out panel (where the CB radio would normally fit) then it's an aftermarket fader. The speaker setup doesn't apply stereo sound to the back, as far as I remember (it was explained to me once) only one front speaker feeds the two back ones. Its easy to check the speakers, just swap them around or just unplug the fader and plug the existing connectors back together. But it does sound like the fader is faulty. Those Add-On faders often gave trouble.
