1 - 9 of 9 Posts
· Administrator
I don't know if it's just getting broken in or if it just likes hot weather but my 1800 has always with a few exceptions gotten 40MPG. The second tank I burned in it got 44, sometimes but rarely 42. Lately it has been getting better and on a 430 mile ride today I got 45. It was really hot though, after 10 AM it was 97 to 99 most of the time and one occasion 102. Ran into a short rain and it got down to 79, short lived and really humid afterward and back up to 97.
The week before we had our run to Tahlequah the gas consumption on my 1100 jumped from right at 40 to about 45. I don't know whether it's something I did because my Goldwing is a work in progress (though I don't recall doing anything much) or the gas stations changed to summer gas. I find if I can cruise around the backroads and keep it under 4K rpm it'll stay at about 45 even two up. Hit the super slab and the associated speeds and it plummets to about 37 mpg.
· Canada Bob
Hidepounder wrote:
My wife and I came back from Eureka Spring Ar this week, she riding her Suzuki VL800 and I my Gl1100A we both averaged 48mpg coming home. I usually only get around 38-42 mpg.
;)document.write('/forums/images/emoticons/wink.gif');
not going to fall for that, we all know it is because your going from the fat part of the globe towards a skinnier part, in other words down hill, thus the improved gas mileage.
:action:
It's the summer blend and the heat. Every bike I have ever had got better mileage during the summer months. The little 450 I had would jump 8-10 miles per gallon during the summer. I cannot however say the same thing about my F150. 17 mpg no matter what.
So what is this summer and winter gas you are talking about?
all I can say about summer/winter blends is that gas companies change the mix for reasons that I do not know.
taken from another web site
There are two key (although not the only) specifications that refiners must meet for gasoline. The gasoline needs to have the proper octane, and it needs to have the proper Reid vapor pressure (RVP). While the octane of a particular grade is constant throughout the year, the RVP spec changes with the seasons. The RVP is based on a test that measures vapor pressure of the gasoline blend at 100 degrees F. Normal atmospheric pressure varies, but is usually around 14.7 lbs per square inch (psi). Atmospheric pressure is caused by the weight of the air over our heads. If a liquid has a vapor pressure of greater than normal atmospheric pressure, that liquid boils. For example, when you heat a pan of water, the vapor pressure increases until it reaches atmospheric pressure. At that point, the water begins to boil.
In the summer, when temperatures can exceed 100 degrees F in many locations, it is important that the RVP of gasoline is well below 14.7. Otherwise, it can pressure up your gas tanks and gas cans, and it can boil in open containers. Gas that is vaporized ends up in the atmosphere, and contributes to air pollution. Therefore, the EPA has declared that summer gasoline blends may not exceed 7.8 psi in some locations, and 9.0 psi in others. The particulars vary, but key considerations are the altitude and motor vehicle density of a specific location. The EIA summarizes the key points:
As gasoline evaporates, volatile organic compounds (VOC’s) enter the atmosphere and contribute to ozone formation. Gasoline’s propensity to evaporate is measured by Reid vapor pressure (RVP). In order to control VOC emissions, the Federal Clean Air Act Amendments of 1990 require that all gasoline be limited to an RVP maximum of 9.0 psi during the summer high ozone season, which the Environmental Protection Agency (EPA) established as running from June 1 to September 15. The Act also authorized the EPA to set more stringent standards for nonattainment areas. As a result, EPA limits areas designated as “high volatility non-attainment” to a maximum RVP of 7.8 psi during the high ozone season. Some States elected to require even more stringent restrictions to achieve local clean air goals, and require 7.2- and 7.0-psi gasolines.​
Butane, which has an RVP of 52 psi, can be blended into gasoline in higher proportions in the winter because the vapor pressure allowance is higher. There are 2 advantages in doing this. First, butane is a cheaper blending component than most of the other ingredients. That makes fall and winter gasoline cheaper to produce. But butane is also abundant, so that means that gasoline supplies increase in the winter because more butane is thrown into the mix. Not only that, but this all takes place after summer driving season, when demand typically falls off. These factors normally combine each year to reduce gasoline prices in the fall (even in non-election years). The RVP is stepped back down to summer levels starting in the spring, and this usually causes prices to increase.
There are some misconceptions that I often seen repeated about this seasonal transition. One is that it is the reason that spring and fall maintenance are done. That is not the case. Most, if not all refineries can carry out this transition without shutting down or interrupting production. The reason that maintenance is done in the spring and fall is that it provides a combination of moderate weather (the inside of a vessel can be unbearable in the summer) and off-peak demand. Vessels must be inspected, new equipment must be installed, catalyst change-outs occur, etc. This is similar to tuning up your car to keep it in proper running condition. But the seasonal maintenance is unrelated to the gasoline transition. In fact, for reasons I won't get into here, seasonal maintenance often complicates the transition.
Another misconception that some have is that they can save money by buying cheap gas in the winter and storing it for the summer. Remember that winter gasoline will pressure up as the weather heats up, and the contained butane will start to vaporize out of the mix. You will end up with less gasoline than you paid for, and you will be contributing to the air pollution problem that summer gasoline was designed to avoid. If, on the other hand, you were to buy summer gasoline and try to store it until winter, you might find yourself having problems getting the fuel to ignite, due to the lower vapor pressure. This would be like putting a little bit of diesel in your gasoline – not very good for your car. So buy and use gasoline in the correct season.
1 - 9 of 9 Posts
