I am trying to narrow down an issue with a set of coils..what should be readings when testing with a meter from:
coil pin to coil pin
on a resistor removed from the plug cap
plug wires...(0??)
plug cap(with resistor in)
I have pulled a coil set(coils, wires, plug caps, etc.) apart and want to test each component separately..anyone have what the ohms readings should be on each piece?
1993 gl1500, 1976 gl1000
:waving:Here's some info from the '80-'83 Honda GoldWing Service Manual: spark plug cap resistance--5K Ohms + or - 10%: resistance through cables and coils--should have 22K + or - 5K Ohms: Coil Testing: Measure the primary and secondary resistance of the coils with an ohmmeter: primaray resistance--0.4 + or - 0.04 Ohms: seconday resistance 1980 &1981--22K + or - 5K Ohms: 1982 &1983--16.7K + or - 1.67K Ohms.
Thanks for the info guys..anyone know is there is a difference between coils labeled
AW82TRI AND BW82TRI???
