At what rpm should my Wing be turning at 65mph???? Charlie G.:waiting:
What wing 1000-1100-1200-1500-1800 Would actually need to know what bike you have!!!!
GL1100...Converted to single carb,the 85mph speedo was bad,so put one off a GL1000,reads top end 160mph. Bike runs right along with fuel mileage around 34 to 40 mpg. Charlie G.
so, you're running a single carb on your 1100 with a 160 mph speedometer? around 65 mph, my 1100 with stock set up turns around 4200-4300 rpm's. I don't know if that helps...............
We need to know what year. Difffenent years had different gearing.
Sounds like my '80 GL1100...should be ok...converted it to one Weber earlier this year,it took 3 carbs before I got one that works well,off a '79 Chevvy Luv Pick up. It doesn't like cold weather,below 60f in the morning untill it warms up,but after that it idles at 1000-1100. Maychange to a hotter runningspark plug...Charlie G.
