1 - 2 of 2 Posts
Weird. My speedo quit working during my 20 mile ride today, so I pulled the cable and it looked fine. Cleaned and lubed it, tested it with my drill, works fine now.
Ideas?
Since it was both the speedo and odometer odds are you have either a sending unit on the wheel beginning to fail or the speedo cable has a problem. Could also be the cable is coming loose from the sender at the hub. If the odometer only failed it would be most likely the plastic gear in the odometer.
1 - 2 of 2 Posts
