1 - 3 of 3 Posts
Banned
trying to hookup the speedo on a 84 and we got the speedo itself to work by hooking up a drill to the wheel end and it turned, but when test riding it would not work, so we figure the problem is at the wheel end where the cable goes in, what could be wrong??
Inside the hub, there is a ring with fiber togs on it. This ring drives the gear inside the gearbox that your sensor reads. You may have broken togs on that ring. You will need to pull the wheel to see it.
The worm gear inside the gearbox could also be broken.
1 - 3 of 3 Posts
