1 - 3 of 3 Posts
Hi all,
My speedo gear hub that sits on the front wheel is bad (1983 I). I did all the diagnostics, cable is good. I found a gl1100 hub on The auction site, but it is different from mine. My old one has a screw for the speedo cable located below where the cable insets. The replacement hub has the set screw on the side.
Will the new one work? Is the 83 hub different from 89-82?
Thank you, Chuck
Yes the 83 is different, if you use a different year drive you will have to change the cable too.
1 - 3 of 3 Posts
