Have a 2003 wing. Started having problems with speedometer on a cool morning the speedometer works fine as it warms up it starts going all over the place. Thinking it may be a loose connection I cleaned all the plug connection. Anyone else experience this problem or had problem fixed?
Does the cruise control and turn signal cancel work normally?
Make sure the battery connections are clean and tight.
Rayjoe
yes the cruse control and turn signal worked all the time
the odometer works fine all the time . when the weather is cool speedometer works fine and on hot days it worked fine for a few minutes then it starts to jumps all over the place
Some early GL1800 had the speedometer replaced on warranty.
The needle/pointer was bending in heat/sun and toughing the faceplate as far as i remember.
That tells me the speedometer itself is the problem, not something external.
