Is there a good way to get in the case and lube the inside of this thing? It has always been wrong on the speed but a gps solved that problem but yesterday it started squealing loudly. Any ideas?????
Nope, solid state. Probably need to grease the cable and hope that solves the noise. If not, you'll need to find a new speedo..
I already greased the cable about 2 weeks ago. It doesn't really sound like a dry cable this was a high pitched squeal. Got a good source on replacement heads?
ebay
you may want to replace cable. my 82 1100 done that and i replaced cable that done the trick.(but you can take it off from both ends and turn it.after i replaced mine.i pulled cable out of the houseing and cleand houseing with brake clean now it turns free so now i have a back up:D:D
My tach cable broke last year so I replaced both tach and speedo cables. I try and grease them at least twice a year. Not saying that a new one won't fix it may have to buy more dang it. thanks for input though
My speedometer started the same thing, I dissconected the cable from the back of the speedo head and noise was gone and I noted an increase in power right away.
I them removed the speedo head and turned it upside down and added a few drops of 10-30 engine oil where the cable connects and them spun the part that the cable drives a few dozen turns. reinstalled and presto no more noise, that was last Aug, Had the bike out yesterday for a 20km ride, still no noise.
hope this works for you, Shimmy.:dude:
Thanks all for the inputs but I think I have the problem solved, the new one should be here by friday or so. Found one on ebay
