1 - 9 of 9 Posts
hey everybody thanx for letting me in.....got a little question my 86 gl 1200 had starter problem soo being broke at the time went party scavaging like junkyard wars. got a good starter off a rebel the starter body was exactly like my gl starter sooo I changed both ends put starter in now SOUNDS like starter clutch but is it possible its spinning backwards and if so without hooking starter up like positive groud what can I do
:grin3:
:welc: I agree it probably spins the wrong way. Even connecting it backwards won't make it reverse. Possibly if you used your original brush holder it would reverse.
The original field type starter would have to have the brush polarity reversed. Like Dave said the end cap/brush holder. If you had a permanent magnet type starter it would run backward by reversing polarity. I am not sure just changing the end plate will give you the results you are looking for. It should go in the opposite direction but I am not sure about the timing between the field and armature being optimum???
I guess ill pull it back apart and see what happens don't really wanna pull my engine but 40 min I can have it out. starter out in 10 min max but engine around 45 min. carb out 5 min took 5 hrs first time I guess practice makes perfect
1 - 9 of 9 Posts
