1 - 9 of 9 Posts
Do you have to pull the engine to work on the starter motor? The manual says yes, is there an easier way?
Buford,
NO!!! YOU DO NOT HAVE TO PULL THE ENGINE. Put your bike on the side stand. Disconnect the neg cable from your battery. Disconnect the positive cable from your starter. You might want to remove the shifter, it just gives you a little more room. Remove the two bolts holding the starter to the side of the engine. Wiggle the starter forward, until the end of the starter spline clears the opening. Tilt that end out and remove the starter. Install in the reverse order. Just add a little oil to the o ring.
Later Rumple
Rumple wrote:
Buford,
Later Rumple
Right on Rumple!! I just pulled mine 2 wks. ago. Didn;t even remove the shifter. Hardest thing was removing the bottom bolt. I bought one of those Extensions where your socket will wobble. Good luck.
You guys have any luck with just cleaning out the starter vs rebuilding it? I just can't wrap my mind around a starter going bad after 40k miles on my bike.
:waving:I've had my '83 Interstate since new and my starter went bad at 20,800 miles. It does happen as the starter is a weak link on the GL1100's and other GoldWings.
manual be a lyin again'!!...relax...pull a stud...2 nuts
yes clean it out....2 things to watch....watch the power stud...dont spin on the inside and pull the brushes away from the amiture to seat on install...peice o' cake
Don't forget to pay attention to the little shim washers on the gear end. How many and how they are stacked. I didn't notice them until I pulled it apart and they scattered across the floor. PITA!!! LOL
Later Rumple
1 - 9 of 9 Posts
