HI Folks
When I push the starter switch...nothing happens. The starter motor won't engage or even try to turn the motor over. Is there a solenoid or relay that typically fails on these bikes that I should check first.
Thanks...Rocket_man
First thing to check is the kill switch, the reverse lever, then the battery. There are 2 starter relays, fuses and several other things that can interrupt the start circuit.
