1 - 11 of 11 Posts
Hi all
I know this has been said in past treads . when removing starter motor is the bike
put on the side or centre stand . got to remove as new brushes are needed to be installed..
thanks guys
adrian
Hi ARKnapp
many thanks for info
adrian
Yea, most folks do it with the bike on the side stand, helps keep the gear and chain in position.
Hi bagmaster
thats what I was thinking off as I didn't want to lose them and make it a bigger job than expected.
:waving:You can remove the starter on the center stand but put it on the side for reinstallation as this will center the gear and make installation much easier.
i did my 1200 a couple of times on the center stand and a 1100 like 5 times on the center stand with no problems.
HI guys
thanks for all advise that has been given .
starter removed new brushes installed, bench tested runs well will be reinstalling tomorrow night.
fantastic site for answers to any problems that one has..
thanks to all
adrian
starter back in . but when hit button relay clcks starter slugish , voltage at battery 11.9v . been standing all week
looked at past forum questions and will try bye passing relay ,and checking all connecters.
any other info would be helpful????
adrian
Voltage is low if your meter is correct, or your connections are suspect. A 12 VDC battery must be fully charged since the starter draws 100 Amps for 1-2 seconds. Charge the battery, a fully charged battery should last 3 weeks at 40 F, if not it may be suphating. Too log on a tender will also kill it if the voltage and amps do not shut off. Make sure battery is good before ripping a starter out.
Discussion Starter #11
battery charged 12.46v. bike running charging at 14.6v .
I may of found why battery was lossing charge the PO had wired the horn and all the xmas lights 26 on the back, and 10 on the front directy to the battery .
the temp here in old blitey has been apox 2-4c at night
( force of habit, goes with the job )
adrian
1 - 11 of 11 Posts
