I had a local shop replace the original starter on my 83 Aspencade one year ago at 40k miles. It ran better and started quicker than it ever has after the replacement. After garaging the bike from a short ride, the starter would not turn, and the solenoid would only click.
Battery is only two months old, so I had it checked. It was fine but needed a small recharge. Also checked the solenoid and all wires and connections. Could find no shorts, loose connections or bad grounds and battery was delivering 12 volts to starter positive. 30 amp dogbone fuse is solid.
After pondering this, I connected a jumper cable direct from battery to starter positive for a brief second only. I heard starter try to turn. After this, starter turned with normal starter button start and bike started. But, I noticed starter was beginning to overheat (with a little smoke from starter area) as bike heated. Shut it down.
What was causing starter to jam? Any ideas? Did I toast it? I've never taken a starter out. Probably could follow instructions I found in the forum, but I'm not sure what to look for. Any help would be appreciated.
