hit starter, just clicks. got new, used, starter silonoid from ebay, put n and it wont even click.
is there something else i should be looking at on this 94 model 1500?
can jump starter silonoid and it'll fire right up.
thank you,
mark:waving:
Well..the start button, the connections in the circuit to and from the ignition, the clutch safety switch and or diode..all connections around the relay..you can test the relay out of the bike..would be my first step as it's new to you..see if it clicks when power is supplied.
The info about is from my work with 1100's but think 1500's aren't too different in the starting circuit mechanics
OOPs I see it works fine when jumped so back to starter switch, clutch safety switch and diode or relay..and ignition circuit connectors..
if i took out clutch diode, would this cause this?
took it out because it had the radio not playing when put in gear
thanks, mark:waving:
From Witchat from my thread on this
A shorted diode should make the Neutral Light burn when the Clutch is pulled, bike in gear or not.
An open diode would let the Neutral light burn, when in Neutral, but would not apply ground to the Starter Relay coil. This could be a part of your problem but the Clutch Switch would still apply the ground to the Starter Relay coil.
Where is this diode located on a 1500? Mine just clicks and lights dim when I hit the starter button but no starter. I wonder if the diode is my problem?
the diode is on the right side. you'll have to remove some plastics. its in the main wiring harness. 2 prong type a deal , looks kinda like a fuse. 1 is neutral diode, the other is the clutch diode.
hope this helps. do you have a book?
mark:waving:
