21 - 40 of 48 Posts
Discussion Starter #21
Is the brown white wire supposed to be for the coils? On the wire diagram I see a brown white coming from the start/stop switch into both coils, yet from the start switch I have (actual gl 1k replacement) I have: y/r, 2 blk, blk/w, and blk/red.
Power goes from the Emergency Engine (Kill) Switch to the ignition coils.
Usually the start switch has the following wires:
1. Input power wire.
2. Output power (when button pressed) to the starter relay (yellow/red wire).
3. Input power for headlights.
4. Output power for headlights. (Does not have power when the starter button is pressed inward)
Discussion Starter #23
Headlight isn't getting power/hasn't functioned since I bought the bike. I've tested the bulb, works fine. I'm not be even seeing lights come on through the center thing where the ignition switch is anymore, nor has the starter switch turned the bike over yet, looking like I've got nothing wired correctly almost
power to the coils is a black/white from the kill switch. the black to the start switch should be hot with the key on, red/yellow to the starter solenoid, black/red to the headlight dimmer switch.
Discussion Starter #25
Could somebody draw me up a stupid-proof diagram of how I'm supposed to wire my coils and resistor to my starter switch?
Discussion Starter #26
Looking at the diagram with all the spaghetti that's on there has me stratchin muh head
The coils do not connect to the start switch. They connect to the black/white wire from the kill switch. I agree on the spaghetti diagrams.
Maybe this will help.
Hey Dennis. What do you think. I did this myself, freehand. LOL///:)
323762
The coils do not connect to the start switch. They connect to the black/white wire from the kill swiotch. I agree on the spaghetti diagrams.
Dave,
The coils do kind of go to the start switch. When using the starter the current to the coils bypasses the ballast resistor. Like the old I terminal on old point type ignition solenoids. That is bypass the resistor while the starter is engaged.
Dave,
I see that, it is not on the aftermarket diagram I have for 1000s. Thanks for that.
  • Like
Reactions: redwing52
I knew you were on top of it but just to avoid confusion I posted. For the most part you were right and the bike would probably even start fine without that circuit, As I said I only posted for clarity.
If you want to look at an OEM manusl go here. Kind of clumsy to find what you need but it is thhere and likely more accurate. And the price is right. :)
Thanks, I downloaded the manual.
Discussion Starter #34
This may be exactly what I needed, I'll see if I have the energy after work tonight, may not be a lot of hours but 7 days on is a bit tiring without having any relief. Still hoping my late night job will let me shift the hours I go in to clean so I can keep that income source
Discussion Starter #37
323791
323792
323793
Alright so, confusion persists with coils: blk wire with the white tags has some what appear to be brownish squares on them, there are two of these, one in the coil wiring and another in the main harnessing where the rest of the handlebar controls wire up, this would presumably be the blk/brown for the stop switch? I've of these two are for the ballast resistor I think then? There's also no blk/brown wire on the replacement right handlebar control assembly I bought and instead have two blk wires.
Also, there's this double/triple insert white/blk wire that I have no idea about, is this just a extra thing for accessories?
Discussion Starter #38
View attachment 323791 View attachment 323792 View attachment 323793
And also, first pic is blk/red right? Tried using a piece of paper to dilute background
OK, you will have a black wire in the bundle of wires near the steering head that is hot with the key on, it goes to 1 end of the ballast resistor, black/brown from the resistor to the kill switch, black/white from the kill switch to the coils. A yellow red comes from the start button to one of the diodes on the left panel behind the false tank, out of the diode it ties into the black/brown to the kill switch. The other branch of the Y/R goes to the starter solenoid. The red/black is to the headlight circuit. (look at the diagram redwing52 posted) If you just match colors in that bundle of wires it should be good, some of the wires might not have a place to plug in.
Discussion Starter #40
I'll pay somebody 150$ if they can get here and get this wired properly, everything I try gets no response from starter switch
21 - 40 of 48 Posts
