Starter wanted plus other parts needed
I need a starter for a 83 1100 goldwing aspencade. Mine has a broken nose cone where the gears go. Or a nose cone would do, even a starter that needs rebuilding becuase I have a brand new rebuild kit. I need one ASAP.
· Cyclebusters.com
I have one here in a box, i cleaned it, greased the gears, it should be a drop on and go.
Still need a starter for back up, I also need foot pegs for driver and passenger, need the electric box that controls turnsignal automatic shut off, also need a turnsignal flasher. also want a rear trunk cover wineberry color if possible, the po cut it up to put speakers in it. I have the floor boards, both sets need a good cleaning and 1 needs new rubber mat with the shifter as well if anyone is interested in them.
Are you still needing a starter? If so, I have one I took off of an 82 Aspy. Not real sure if it will fit an 83. I know there were some changes between those years and even though it's an 1100, some things don't interchange. I replace this starter because the brushes inside were burning up so it will need rebuilt. Or at least new brushes. PM me if you are interested.
