Hey Artmann...someone far more knowledgeable will be along soon, but if you search "starter", lots of info on removal (I believe it's as easy as 2 bolts, hold shift lever down, and pull starter back while bike is on sidestand...don't move bike/run engine at this point as starter cog could move, making reinstallation mission impossible).
If you put 12 volts on the starter, bypassing the relay, does it turn? Just curious, as it could be bad contacts in the relay.
Guru's will be along shortly I'm sure!!
Dave
