i have a friends 1100 so i can do some work for him one problem is the
starting of it. you press the starter and it justspins with out engageing
the starter clutch till you let go of the button and then its more a grate
just before it stops. but if you bump start it let it warm up it starts on the button but
the next time you try to start it from cold its the same is it the starter clutch if so is there a quick fix other than engine out or is there something else
thanks Glenn /uk
thanks Glenn /uk
