BATTERY IS GOOD, STARTER IS NEW AND I JUST REPLACED THE SOLENOID......MY '81 GL1100 STARTS 5 OR 6 JUST GREAT , THEN NOTHING. THE HEADLIGHT DIMS LIKE ITS SUPPOSE TO, BUT THE STARTER WON'T SPIN IF I JUMP THE SOLENOID, IT WILL START. ANY HELP OUT THERE?
Start by "Spraying some "Contact Cleaner" in you "Switch" on the handle bars!
Radio shack has it!
Thinking it's between the switch and the solenoid?:baffled:
Welcome to the forum, oldwinger. Does the starter relay (solenoid) "click"? When checking wiring, don't forget the negative (ground) connections.
Old School Guru
Yes this sounds like a bad ground somewhere, or a corroded wire connector at some point.:)
Gene:waving::11red::11red::11red::cooler:
