Stator Gone, HOW DO I Know 1200 GL
620 Views 3 Replies 4 Participants Last post by  steve worth
Ok, I smelled electric, checked the 4 prong clp, it is melted, voltage at the Battery while running **** 12.2 volts, how do I know for sure it is the alternator .
should I check the regulator or something else??
Check the output at the 3 yellow wires at their exit from the back of the stator, that way you are bypassing the regulator completely.
Do you mean the 4 pin plug on the starter relay? Fix that, it may not be letting the charge get to the battery. If you mean the 3 yellow wire plug in front of the battery cut it out and solder the wires together. 1100s seldom have stator problems, assuming you mean the 1100 in your profile and 1200 is a typo.
No. there's a plug shortly after the 3 wires exit the stator- near the front of the battery. It may have been cut out and the 3 wires soldered, (if not it needs to be!). With the wires disconnected and checking across the 3 combinations of pairs you shoud see around 70v AC per pair at 3000 revs. Stop engine then test again, looking for continuity to ground this time- there should be none. There is a lot of GL1200 stator info on the forum, including how to replace it with an external, (but hidden) car alternator. Stator replacement with another stator is an engine out job, and some have been unlucky enough to have the replacement fail in short order, hence the car alternator modification. Try looking under "search" for "Stator" and "Poorboy"..........Steve
