I know that when I test the stator on my 1200 that I disconnect the 3 yellows and check the wires coming from the stator for resistance but I was also told to start bike, change meter to AC to test for voltage & then have some one hold throttle @ 3000rpm & check wires A, B & C. Does this mean the 3 wires from the stator or the 3 going to the rectifier? And before anyone make the good hearted suggestion, I will not be soldering thes 3 wires as the stock plug is in near new, perfect shape & my soldering is far from desireable. I do chesk thjis area regularly as per all the suggestion about this plug burning up. I just need to know how to check the stator And also how do I do a load teast on the battery. I have a H-F Multimeter. Thank you in advance.:?:action::action::action:
