1 - 12 of 12 Posts
Made a bearing installer for bottom bearing on steering stem. It's made out of the inside of the old bearing and is welded to an 11/2" pipe with a cap on it. A couple of good hits with hammer and you will drive it home. I cant seem to get pics onto this site so anyone interested in some pics will have to get me an e-mail address and I can send it as an attachment
just curious what tool did you use to remove the lower stem bearing???, JB
A cold chisel. About 4 hits with hammer and it came off. Just be careful not to marr the stem.
I used a dremel tool with an abrasive wheel to cut through the race, just enough that when I put a cold chisel in the groove I made, the race split with no damage to the stem.
When I re-installed thebottom bearing, I put the stem in the freezer over night and used the old race and a piece of pipe to drive the new bearing on as soon as I took out the stem from the freezer. It didn't take much effort to get it in place.
Regards,
Hobie
Here are two photos of the Genuine Honda Socket tool I bought from Cyclemax. Very well made, good heavy weightand extremely solid. Looks and feels like it will last forever. Having spent an absolute fortune on my wing I felt it essential to spend a few quid and have the right tool for the job. Especially when adjusting and setting the correct torque on something as important as the steering head.
Very nice tool! I made mine from a Ridgid hole saw. Torque on that nut is not that much. I will probably use it one time and I am only out $11.00. If you are a bike Mechanic you need the good tools. If you can make a suitable tool for far less than why not. Did you buy the socket for that top nut as that requires much more torque.
The socket is for the top nut on the GL1800 which requires a very accurate torque setting. You give it a good torque to get the bearings to sit in properly then you back off to the recommended setting which I believe is 18lbs torque. Unfortunately the nut is designed with a head the needs the above tool to turn it and you need it to make the accurate torque adjustment. You can make a DIY tool from a socket but I bought the Honda one as I was buying other stuff and I bought my Dollars when it was $2 to the £1 and brought it home with me on the plane from Vegas. I will probably end up lending it to others who may need it over here in the UK after I have installed my 'All Balls' Bearing kit. It was a lot bigger and solid than I expected and looks like it will stand a lot of abuse. Really good thing for my toolbox.
Discussion Starter #10
Ah, the bearings and nut configuration on your's is different from the 1200. I got ya now. Makes good sense. I just installed my stem bearing a few short minutes ago after pulling it from freezer. Tool works great,no effort at all getting it on. My wife is pushing me to get the bike back together.
Discussion Starter #11
My races came out easily as did the bearing. I used a 3/8" rod I bought at Home Depot and about 4 taps and it was out. Sounds like you did what I did only I welded mine to the pipe and ground the inside of the old bearing piece to make it easier to remove. Whaever it takes to get the job done!
I use a brass drift to knock the bearing races out of the steering head. Just takes a few taps on each side to walk them out. A couple of screwdrivers or small cold chisels tapped under the lower bearing will start it up the stem. It's important not to hit the stem itself. John, Jluvs2dive found a piece of tubing to drive the lower bearing back on. I think he said it was a shower rod or some such from Home Depot. He said it pushed the bearing right back on easily. I did it the hard way alternately tapping (very carefully on the inner race) with a small punch. John's method works easier. I also heat the bearing up and freeze the stem prior to reassembling. I think John said he didn't have to do that to get the bearing back on with the piece of steel tube and a hammer.
1 - 12 of 12 Posts
