Does anybody know a good product for (temporarily) sticking sandpaper to glass?
Going to be putting member Ommari's SEi's cylinder head back on tomorrow.
Wondering, or maybe second guessing, if there is a better way than two-sided tape to stick the sandpaper to the glass for final surfacing.
Some kind of temporary spray glue, or...?
How about hair spray?
With most contact-type cements (spray, let dry, then press together) a little lacquer thinner will dissolve the cement allowing separation. You might lose a piece of sandpaper in the process...:surprise::smile2:
Yeah, I have a small non-aerosol bottle of hair spray that I have been using for years to put grips on.
Turns out we couldn't use the glass...
I bought the ¼" glass and the fiber board. Doubled up the board & glued it. Took it over to Frank's to square it up on his table saw. Flex glued the glass to the now double thick board, bought some handles to put on it, and it turns out we couldn't use it because the dowel tubes wouldn't come out of the head and block.
'Spose I'll use it some day.
Thank you all for your suggestions.
I have a ton of those "Never thought about that" moments.
