I got my bike back from the shop and still have the same intermittent problem. The bike has a new battery,starting motor, wires, plugs, solenoid, and I also replaced the ignition amplifier. I cleaned all the terminals and still the engine will just "grunt " when I hit the starter switch. Here is something I have discovered. If I have the engine kill switch in the off position the starter turns the engine over "EVERY" time. As soon as I put the kill switch back to run the bike won't start. Does this sound like I have an electrical problem? Any more input would be appreciated. Thanks
