1 - 20 of 21 Posts
Greetings---I just bought a non op 1981 GL1100 and found that they had stripped and re-drilled one spark plug hole. They drilled the hole so large that I cannot use a heli-coil. (It has an old monster spark plug in it.) How have you guys solved this problem? Is there any way to salvage this head? Thanks, Lew
Monkey with a Football
I'd just get another head off of eBay if it were me.
If the hole is too big for a Helicoil, I would say it is not worth spending time or money on.
Get a replacement head on Ebay. They are not expensive.
Token Canuk
The Ferret always comes out on top :cheeky1::cheeky1:
We are warmer down here so our reaction times are faster.
Token Canuk
:p:p:p:p:p:p:p:p it's still -25 with the sun on the thermometer.
Then get you old bones in that hot tub!:cheeky1:
I used to work on air cooled VWs that was a common problem.KD tools uset to have insert that were made like a bushing instead of like a coil they worked fine on a lot of oversized plug holes.
Token Canuk
Ya, Santa had to take it back :gunhead::gunhead:
No I didn't. It's just covered with snow. And deer piss.
I've used those before also in my old sand rail. They work better than helicoil, but I still think you're better off with used head.
You might post a wanted thread in the "For Sale" forum. You might find a member with an extra lying around.;)
Banned
Gotta gl1100 head for sale, setup for left side , 25.00 plus shipping , about another 20.00 in great shape. picasso.
Discussion Starter #14
Thanks for the help. How do I measure the size and thread count of the much larger spark plug? Thanks, Lew
I have a set of metric & NF & NC thread gauges plus a plastic board with labelled metric holes in it. Very useful.
You could see if a 14mm sparkplug will screw into the hole & that would tell you the size. The thread pitch is probably 1.25mm
I would go for the used head for $25 instead of messing with oversized plug which can't be the same as oem plugs. May end up with other problems due to differant plug heat range ect.
The larger insert that I have used that looks like a bushing is called a Keensert.
Do a search and you will find pictures and instructions.
The Keensert is much larger than a helicoil and should fix your problem.
Our local NAPA carries them in a kit with the proper sized drill and a disposable driver.
After installation there is four stakes that get driven down through the threads on the outside to lock the insert in place.
This is a quick and cheap fix to see how the engine runs before you spend money on a head you may not need if the engine is trashed and only good for parts.
Your choice.
I would only use those helicoil in non structural/ non stressed application as last resort. I had been in a boat where the sparkplug blew out like a bullet.
Used head a good idea.
Disfunctional Nimatode
I'm with OldMisterBill............ I took a head for a 6hp evinrude outboard to my machine shop. They drilled out the head and put in a bushing that scewed into the head, and the spark plug screwed into the bushing. Works perfectly.
luv U longtime.
Dancinbear
The keen sert allows you to use an origional spark plug.-never had a failure with them.The good thing is you are now installing the plug into a steel threaded hole instead of aluminum or Magnesium so galling is not a problem any more.
1 - 20 of 21 Posts
