Hi All
I am in the process of resurecting a supposedly siezed (another story) GL1100 and when I took the engine out the long bolt that fixes the front of the engine to the frame is siezed solid in its tube housing (the tube runs right across the base of the engine at the front)
So I tipped the whole engine on its side and clamped on a rubber tube and filled it with release oil but after 2 days the level has not gone down :? so its well stuck
My thoughts are the only options are
1 leave it alone and struggle to reinstall
2 start applying heat to the casing in the hope of it 'cracking' loose
Anybody had to do this and did it cause any problems?
any more ideas on how it could be freed?
Thanks Rob
Hi All
Thanks Rob
