I have been having trouble with oil smoke on the right side of my 76 gl 1000,I took it to the local honda mechanic and he feels that the oil ring is stuck on the back cylinder,the valves ,guides and valve seals were done 2 months ago so that shouldn,t be the problem.the mechanic gave me a can of a product called omc engine tuner that he has used with alot of success to cure stuck rings.it made the problem worse,so i changed the oil and filter and added some cd2 additive,this seems to have heped the smoke but now the bike has no power below 3000 revs,above 3000 works great,any ideas or suggestions?thanks in advance
