Whilst checking write ups on cruise control problems (mines surging).
I came across a lot of references to sub filters. I was able to get the sub air filter number but not the cruise filter. Thanks to the pictures on the site my Honda shop tracked it down. So, I thought I'd post them in case anyone needs them in the future.
17253KT8000 Filter, sub air
36532MN5005 Filter, Cruise Control
Hope these numbers come in handy.
Jim
Lost on this *****
Noted,,,,,,,,,,,, Thank you.
does anyone have a picture of the secondary or sub air filter for the 1995 1500. i have looked all over for it and cant locate it. i have replaced the main filter but never the secondary.
Old School Guru
You can also get a filter wrap for a lawn tractor, cut the filter wrap (it is a foam outer layer that goes around a paper air filter)to fit the sub filter and other type filters. Cost me about 2 dollars for one at the local hardware, and I have enough material to make a lot of these small filters, and it is the same material as the original stuff.:)
Gene:waving:
02 GL1800 w/Auto Pilot
Just another ORF!
Here's a photo I took, showing you where it is(under the right hand fairing pocket)and the part #
thanks for the numbers, However I to have purchaced the lawn mower filter 1.89 and will have enough material to make several.
