Sub-wire harness D
893 Views 4 Replies 3 Participants Last post by  wda-83wing
I need some help in identifying where this harness, in the pic, hooks up to . The PO had cut out the fan circuit, probably because the thermal switch didn't work he ran a ground off the main harness to the engine. I need to restore it to original. The bike is an '81 GL1100 I
1) I have no I dea where this goes -it looks like a ground
2)goes to the main harness
3) goes to the fan
4) goes to the oil pressure sensor I think
5)goes to the temp gauge
6)goes to the thermal switch
I looked at the wiring diagram, but addmittedly, I'm weak in this area. Any and all help would be appreciated
1 goes to the neutral switch
6 goes to the fan thermo switch
5 goes to the temp sensor for the guage
4 goes to the oil pressure switch
3 goes to the fan motor
2 goes to a plug that goes back to the ign
I think that's right I'm going by memory
by golly--i think you`ve got it.
Thank you. I have to follow the neutral switch wire. I don't know where he has it going. One more quick question. The pic is for an '81 and it shows a connector with more than 4 leads, yet my bike has a 4 lead connector that is factory installed. How do I proceed with the rewireing? any suggestions? Thank you
i belive the #2 plug will match up with the one thats on top of the front tin on the left side.there is a harness holding tab just before the plug. i think--gad its been awhile sence i`ve looked.
