Well after two days here is what i have done.
Removed bags and trunk,Remove rear wheel inspect drive splines, Drain, flush refill finaldrive. Wash wheelClean inspect and relube drive splines,reinstall rear wheel. Wash baggs & trunk,wash all brackets and wax to prevent rust. Reinstall said bags and trunk.
Drain all brakefluid and flush with fresh fluid fix broken brake line. Bleed brakes and they all work fine.
Drain antifreeze,remove timing covers, change timing belts. Reinstall timing covers and radiator, Fill with fresh antifreeze. Remove front wheel inspect front wheel bearings and reinstall. Change oil filter and fill with fresh oil. Spin engine over till the oil pressure light goes out.
Put a couple gallons fresh fuel in it and start it up. Took alittle coxing but engine firedup
Watched mouse house blow out if exaust hehe.Check stator output at idle. 14.67V
stator is in good shape.
With her idleing put in first she dies
clutch plates are stuck
Put in first start her up and start working the clutch and brake. Clutch plates brake loose
Shifting now works fine.
Rode around block YEAHHHHHHHH
Sunday will spend day washing and waxing and shining
Then drive the car to work
Monday go to DMV transfer title license her.Stop by DOL and get licenedCome home call insurance company and get leagle.
Not to bad for an 86I setting 4 years with under12k showing. IMHO anyway.
