Dear fellow bikers.I have had three occasions where she will just cut out completely,suddenly,and last night right in front of cars!Hair raising.I have changed,plugs,filters,fuel and air,cleaned carbs,check the fuel ****,the vacuum lines,battery,fuses,loose wiring.etc.I believe that these bikes were called back by Honda in the beginning .Faulty,sensor,of some kind,if your bike falls over?Where is this thing?I need to use the bike daily,Pastor for bikers,so any help is well received.She does it in all kinds of weather,hot or cold.
This is what happens.Riding at 80 mph or higer,no warning,up or down hill,but usually higer speeds,she just cuts,all dash lights are on,fuses Ok,I then coast to a stand still,wait for a minute and start her up again.Perfect.No I believe not fuel starvation,new filter in line for the fuel.10 mm in and out size.Fuel **** assembly,seems Ok.
But sometimes she will perculate,flood,after I have ridden her,then I will start her,smell fuel,wait for it to clear up,and idle smooth and then go.
I am baffeled.
KIND REGaRDS.
:XDan Booysen.Messiahs Disciples South Africa
I am baffeled.
KIND REGaRDS.
