Did the belt change yesterday. A little history, The bike is a 1997 model built in Aug 1996. It's always been a little slow starting from a standing stop. When I bought it in July 2009, it had 6,500 miles on the odo. Today the odo shows 29,628. What I'm trying to say is the belts I removed were stamped with the HONDA name & were factory installed. Once I removed the timing cover I found that the timing marks on the right cam was off by 2 teeth. If I lined up the marks on the right cam, the left was off by the same amount. Lining up the crankshaft timing mark, the left belt was right on & the right belt was off. Anyway I was able to get both cams lined up with the crankshaft & all is well. I hope this will give it a little more pep off the line.
BTW, the old (16 year old) belts looked brand new, with no cracking & the teeth still had sharp edges. I used Rudy's how to posting which made the job very easy. http://goldwingtech.info/timingbelts/timingbelts.htm Thank you Rudy......-Rich
