82 GL 1100,
symptoms: 1st noticed in summer, 08
Fan runs when hot, seems to drain battery, as starter button get only a klick.
After 6 12 mins sitting fan stops.
Few mins later, press starter button, as starter labors from drained batt. manages to start engine.
symptoms now: Fall 08
Extreemly faint click when starter button is pressed.
With new & charged battery: lights slightly dim as starter button is pressed.
Will start if push-started down thestreet, and seems to run ok.
Noticed oil leak from the small hole on bottom cover between starter and engine.
What are remedies?
Could it be that the clutch is mal-adjusted and will not allow the started to engage? If so how do I adjust this. ( have an owners workshop manual) In the manual there is a terrible black and white photo of the clutch cover access cap. The photo is an extreemly close up and I don't know where in the motorcylce it is showing. It doesn't indicate left side, right side, front, rear, or anything. Nothing else in the photo indicates just where this access cap for the adjuster arm is.
should I try a clutch adjuster armadjustment, (if and when I find the adjustment arm) ?Also which directionof thescrew takesout slack. (if I need to take out slack)
82 GL 1100,
What are remedies?
