My expeience with Progressive hasn't been quite what I wanted.. I put a rear shock on my 1800, and it's totally worn out after 25K miles. The front benefited from stronger springs, but a straight rate would have been a better choice.
I have an 1800, so I'm more familiar the suspension deficiencies of that bike than on a 1500, but they are pretty similar.. Spring rates too weak for an 8-900 lb bike, damper rod forks, poor to no rebound and compression damping. The 1500 at least uses roller stem bearings, not the ball bearings more suitable for a bicycle they went to on the 1800..
Your choices include:
Progressive..
The Gabriel or Monroe of the motorcycle aftermarket suspension market. Better than stock, but not great, and doesn't address fork damping issues. Also, these are progressive wound springs, and a straight rate spring gives more consistant action. As I mentioned above, my Progressive shock is gone at less than 25K miles. Not ideal for a $700 investment.. ($500 shock + $200 install)
RaceTech..
Much better.. Straight rate springs, of the correct weight, and the Gold Valve kit addresses and fixes the damping issues. Reasonably priced, and if you can rebuild forks, you can do this upgrade. The rear shocksetup is matched to the front end, and comparably priced with Progressive. Or they have an upgraded shock that looks like a real heavy duty winner, at least for the 1800..
http://old.racetech.com/evalving/english/Srchpr.asp?bikeid=212&manufacture=Honda&model=GL1500SE&year=95%2D00&TABLEINFO=street&langname=english
Traxxion..
Probably the best. Totally gut and replace your fork innards with high quality cartridges and suitable springs. This install does require you to machine off a part of your fork tube to remove the cup from the damper rod side, and Traxxion has been reluctant to have the end user do this, but since you are in the UK, perhaps they have a different plan.. I know there is an 1800 rider in Australia with the Traxxion setup, and I'm sure he didn't ship things back & forth.. Traxxion uses a custom built Penske shock, and it works very well on he 1800.
Look around the Traxxion website, and check out Max's video. He's opinionated, but he's right..
http://traxxion.com/hondagoldwing.aspx
I have done both RaceTech and Traxxion upgrades, and have ridden both. If money is no object, go with the Traxxion full monty. If budgetary considerations apply, perhaps the RaceTech GoldValves, decent springs, and a new shock would be more affordable. You can do this incrementally, by the way.. one end now, the other later. The problem with that is that as soon as you fix one end of the bike, you notice how bad the other end is...
Dave
rocketmoto.com
